Hi All,
I just started using edgecam (v11.5) a few weeks ago and I must says it's a whole different world than surfcam!...it was quite a struggle at first but now I'm getting pretty used to it.
I have some questions and I guess I'm looking for the way in this system to do some things that I could with surfcam...Here goes...
1. Is there a way to click on a point of the displayed toolpath to get locations? I know you can simulate through the toolpath and watch the tracking window, but sometimes you can't move it to the right location etc, especially between rapid and feed.
2. I know the best way I learn is by real world situations. Without a license in surfcam (yes, i know i'm not using surfcam) you can open a real file that you are working on...you just can't save or post in demo mode. Is there a way to work with a real file in student mode? I don't care if I can't save what I've done...I just want to learn how to do it so when I get to my work pc I can do it again.
3. Let's say you have a part toolpathed and you realize you forgot a tool/operation or you change your mind on how to do a section of it...Is there any way to add a tool and paths where it should be in the program instead of creating at the end and dragging into position? (A sliding bar like solidworks would be nice in this sort of situation...slide it up and work from the middle)
4. When I open ec and start to create a new file, the default is MM and the display tolerances are like .01 and .1...how do I set the default to inch and a better display quality?
5. How can I print out of ec to scale? Is there a plot function? Also, are there other more advanced printing options somewhere? I print mostly to a black/white laser and I'm pretty sure there aren't any greyscale options...when I try to print, let's say yellow geometry, it won't print out and the other colors are different darkness when printed.
6. The auto-regenerate seems kind of unreliable so I regenerate everything pretty much every time I make a change now. Is this something others have issues with too?
Ok, I think that's it for now. I like the system and I need to know more. If anyone out there has any input on any of these questions I would really like to hear it! I'll be going to classes for the software but I'm not sure when my company will send me, so I'm just flyin' by the seat of my pants!
Thanks again! |
