Burnt out motor and gecko 201 ??? | | Was wondering if others use limit switches on the z axis? Had mine hooked up and was playing around with it when it quit. It had bottomed out, so I'm wondering if I burnt out the motor? In the process, I think it burnt out my gecko 201 also. I've got the candcnc system. The fuse to the z axis blows even when I remove the cables to the motor. The power light on the gecko does not come on either. Is there a way to test the motor to see if I burnt it out? What about the gecko 201? Thanks for any help. |
