Old 04-24-2007, 03:35 AM
novacustard novacustard is offline
novacustard is on a distinguished road
Engraving Advice Please!
Hi.
I have been trying my hand at engraving, but without the success I had hoped for...I bought a half round cutter with 0.003" tip - one of these:
http://www.bitsbits.net/index.php?ma...ed0a0bfb982ae3
I used it in a Bosh Router at about 24000rpm, mounted to my CNC machine:
http://www.cnczone.com/forums/attach...9&d=1164274624
To cut this: (see attachment)
Cuts were 0.004" (0.1mm), down to a maximum of 0.02" (0.5mm), feed rate was 4.7 ipm (2mm/s). Material was 1mm thick sheet silver
The other attachments show a close up of the work and two chips in the tool.
I'm guessing that the tool got damaged at some point during the cut and then the damage contributed to the poor(!) finish...
I am at a bit of a loss really. I had previously cut two of these out, but was not really happy with the finish - The first I cut probably had a better finish of cut - I used a higher feed rate of around 12 ipm.
The other difference between 1 & 2 and no3 was that I was liberal with WD-40 and removing the swarf, whil I did neither for no.3
So is that it? I should have used lubricant and removed swarf?
What about the depth of cut and feed rate?
Any help gratefully received...
Richard.
ID:	36073   Click image for larger version
ID:	36074   Click image for larger version
