Originally Posted by sailandoar What process/programs/details are you using.
Corel is the CAD program. Are you generating an output file that is being used by a CAM program to generate the g-code? etc etc |
I am generating a drawing with Corel, then saving it at HPGL and and then using Mach3's Lazy cam to read the HPGL file to generate the GCode.
Basically all I am after is a decent FONT that I can use for engraving. Stick40 font is great if I can only put spaces in it.
