Old 04-20-2007, 07:43 PM
sco999 sco999 is offline
sco999 is on a distinguished road
Originally Posted by jpawelk View Post
Please see the attached document.
Attachment 35793
Yes I have that document along with the software and drivers.
I was on the phone with mike who was the best tech support guy I have ever dealt with (milltronics IT expert) for about 3 hrs today trying to get this thing going. At first it was set up using netbeui no luck there error message 31 problem with attatched device!!! So then we set it up with tcp/ip so we could get some diagnostics via pinging etc. Still same error message. the mill is talking to the pc just fine but there seems to be a problem on the pc end with the share. I had to set up a user on the pc with the same name as the mill and set it up as a power user. gave everone full control in the share folder still no luck. The pc has two network connections wireless via usb adapter and wired via ethernet card hooked directly to the mill via crossover cable. ping just fine in both directions but when I load the control or use dos command: net use P: \\computername\sharefolder I get the error 31 problem with attached device. Tomorrow I will try with my laptop and see if I have better luck.
