These limit switches are connected like that because you first hit the home switch .If you go further you hit the one called Limit switch 1(LS1).Further than that you hit the Limit switch 2(LS2)LS1 is what you can call a "soft hit switch". LS 2 is a "hard hit Switch"
They are all affected at the same time.Home-LS1-LS2, in that order. |
