Old 04-15-2007, 07:53 AM
wjfiles wjfiles is offline
wjfiles is on a distinguished road
Wireing Lathes
There is no need to connect the motor base to your lathe IF your workshop wiring has been done correctly.
The Earth {green & yellow) wires and the common Black or Blue should be Common throughout the whole electrical supply system.
I have seen motors in a home wired workshop connected to a lighting circuit with no earth wire. Only recommended if you intend a short life span.
YOU SHOULD HAVE A QUALIFIED SPARKY LOOK AT YOUR SETUP. He has equipment and knowhow to determine the safety of the installation.
WJF
(another aussie)
The More I Learn The Less I Seem To Know
