If the DRO is new and you swapped scales to the DRO and the problem followed the scale, then you either have a bad reading head or the head is not aligned to the scale properly, Most makes will error out if the head is grossly mis-aligned.
You could also remove the reading head, usually be sliding off the end of the scale and make sure it is clean also, use alcohol and lint free soft cloth.
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
