  #11
Old 04-12-2007, 01:29 AM
mxtras's Avatar
mxtras mxtras is offline
Silver Member
mxtras is on a distinguished road
Originally Posted by Stuff-Builder View Post
Hey Scott, .....As far as feeding goes, you could probably either push the part through by hand or use a pneumatic cylinder to push the tube. A set of drive rollers would work too - perhaps one set in front of the sanding sleeves and one on the other side. Kind of a push-pull arrangement.
I hope that helps some!
(Another) Scott
Yup! Having the ability to run the tubing through a process once and finish all sides simultaneously has some major advantages that would justify spending the time to figure out the arrangement.
Scott
Consistency is a good thing....unless you're consistently an idiot.
