Old 04-09-2007, 11:42 PM
fivaxis fivaxis is offline
fivaxis is on a distinguished road
I use the 2L one, it works pretty good. It does continous 4th axis engraving which is what I needed. Only problems are 1 when you use the program to make text it doesn't output the program properly, so you have to save the text as a dxf file and then import it as a dxf. It only takes a second so it's not too bad. And 2 in the program usually the first Z+ move (after done with the first cut) for some reason puts x y and a into it so it would leave a mark, I just edit out the x y and a.
