I assume you are talking about entries. What version are you using? In V8.0 and up there is a Entry & Exit tab in the Contour and Roughing process for different types of ramping entries and exits. If you have an older version use the Helical entry to ramp in.
Another trick would be to create your operation, do an Op to Geometry, create geometry to connect to the converted geometry, and redo that operation but this time select the geometry and use the centerline marker. Kind of involved, but you can do anything you want this way.
The helical entry should do what you want and I would try that first. I use it all the time especially when machining steel, titanium, etc.. |
