Old 04-09-2007, 01:46 AM
reachraghu reachraghu is offline
reachraghu is on a distinguished road
feed actual
Is your feed-override switch okay? Pls check for any short on the switch wiring. If okay then, might be the axis servo motor is not rotating at full rpm.(Axis motor rpm multiplied by ballscrew pitch gives the feed rate.)
By the way is your m/c with a fanuc?
