You might think twice about boring a Bimmer engine. Find out if the bores have a special coating like "Nikasil" or other. This requires extremely expensive equipment to replace the coating. Without the coating, the aluminum block will wear out in no time. There is the limited possibility of sleeving the bore with a cast iron liner. All above is for aluminum engine blocks.
__________________ DZASTR |
