Thread: Don't Do It?
  #12   Ban this user!
Old 04-05-2007, 07:30 PM
jo_tigger jo_tigger is offline
jo_tigger is on a distinguished road
Xylotex enable
Regnar,
Sure no problem. You might want to read the following document from Xylotex if you haven't alreadyhttp://www.xylotex.com/XS3525V400.pdf. Page 6 has the enable info. Basically there is a 5 pin header between the parallel port and the breakout screw terminals. You remove the jumper from the enable pins located by the step setting jumpers. This will take it out of enable mode. Then connecting a switch between the ground on the 5 pin header and the other 4 pins. Closing the switch will then enable the drive. I have a DeskCNC board so I use it for my E-Stop which requires a normally closed switch.
Header Connections
Using 1 Switch ($) to enable/disable all drivers at once.
X Y Z A Ground
| | | |___|
| | |_____|
| |_______|
|_________|
Using 4 Switches ($) to enable/disable individual drivers.
X Y Z A Ground
| | | $___|
| | $_____|
| $_______|
$_________|
ID:	34878   Click image for larger version
Name:	Xylotex Board.jpg‎
ID:	34879   Click image for larger version
Name:	Crank and E-Stop.jpg‎
