Originally Posted by fade2black About how many cans of Kilz is everyone using to prime all the MDF parts? I'm wondering if I would be better off ordering a case online then buying the individual cans at HD or Lowe's. |
Paul,
Looks like you are off to a good start! Can't wait to see pictures of your progress.
I think I ended up using around 7-9 cans of primer (gray) so it would be easier to tell how good I was covering with the white. Used about 10-12 cans of white.
My table was built from a kit I purchased at Rockler. It is a bit to high with the casters on it so once I have it in my garage I'll use the orginal bolt type feet that came with it. Right now the work surface is at about 50 inches.
I want to end up with at about 42 to 44" to make it just right for me.
The frame I purchased when assembled is 36"d x 42"w. With the top I have about 8" inches at each end of the machine whick gives me a place to set tools and so on.
Bob
