Old 04-02-2007, 09:37 AM
Dave1's Avatar
Dave1 Dave1 is offline
Dave1 is on a distinguished road
To install the draw bar back into the machine. I stack the washers (grease them well) and put the top bushing and nut on real loose. Snug the setscrew on top. Drop the assembly in the hole, install the ball cage from the bottom up. Tighten the cage against the shoulder on the draw bar and sung the setscrew. You will need a 1/8 thk. piece of flat bar 1 in wide to do this. Then, remove the free play from the washer stack using the top nut and tighten 4- 4 1/2 turns and snug the set screw on the top nut and your good to go.
Hope this makes sense,
Dave
Schneider Machine
A force of one
