Thread: Help, new SX3
Old 04-01-2007, 06:19 PM
Flatline's Up! Flatline's Up! is offline
Flatline's Up! is on a distinguished road
I believe that connector is under the panel at the top/rear of the column. It has 4 phillips screws to remove (on mine anyway). You have to feed that long wire set up under the column rear panel and connect it under the vented 4 screw panel you removed.
(woohooo I helped someone... and mine still doesn't go lol)
