ToyMaker, Are you saying to use the 220 input but connect it to 110? This is the same transformer that I used in my first servo box. I have a connection diagram on my website under the building the servo box. I used the black and the 110 Red wire for the input. This transformer should give you close to 36VDC @ 10 Amps when you are finished.
http://www.homecnc.info/servo%20box.pdf
