Old 03-31-2007, 10:41 PM
metalworkz's Avatar
metalworkz metalworkz is offline
metalworkz is on a distinguished road
Do you have any movement on any of the axis? If not and if it seems like there is no power to the motors you may need to take the cover off the control box and check to make sure there are no disconnected wires inside.
Mine had no movement on any of the axis and upon inspection I found several wires disconnected. Once I got them connected then things started moving and axis movement is not a problem except for a reversed X axis which is easily corrected. Now I need to replace my Y-axis home switch and get my spindle contol under control.
Regards,
Wes
