Thanks alot guy's for the imput I guess I should have posted the control type,I have an older Fanuc OM ,my alrm in the book for a 409 alm is spindle overheat ,and on the amplifier it's alrm -01 The books reads spindle motor overheat.So what I did 1st I sent out the spindle Drive (Amplifier) when that checked ok 2nd I sent the Spindle motor out to be tested because there is a thermo in the motor but that also checked out ok.I then worked with the Tech over the phone and he thought everything then pointed to the Drive again So for a 3rd time I sent it back under warra
nty,Again nothing wrong with it...So at this point very frustrated I'm looking for a good Tech to bring in I have wasted to much time.
Across the 3 legs checking it with a voltage meter I have 208-218.
Thanks..... |
