So you are getting no reaction from the machine? Or does it not recognize your port when loading Mach?
Have you tryed to jog it?
Jogging:
Press Tab and the either use the Hot keys or use the mouse to click on the icons.
Spindle On:
Make sure you are in CNC mode and press start on the machine head. Then select a speed in your rage like 500, go to MDI and type S500 M3. M2 to Stop
Coolant:
If you have the coolant option hooked up simly go to your MDI and type in M8 for coolant on, M9 for off.
Personally I am still debugging a few issues with my SX3 and it has been in my garage for 2.5 weeks or so. |
