Old 03-28-2007, 12:18 AM
GAWnCA's Avatar
GAWnCA GAWnCA is offline
GAWnCA is on a distinguished road
Hey Sloper, I can hardly wait to see what you produce in a video.
Originally Posted by sloper sty View Post
venomx,
I've been cutting airplanes for 2 years with Foamworks exclusively.
As mentioned go to the site and download the free trial programs.
At a point I had a video out showing going from autocad to cadwords to foamworks.
In short you need to set the order of the lines.
They are not set that is why you got zig zag.
Load dxf file into foamworks
make a new blue layer
trace the dxf file counter clockwise starting from the right
working your way down covering any horizontal positions.
and exit on either side
Theres a few hurdles:
Sometimes in foamworks you can't get the dat file to go down to 0
A few methods resolve this fairly quickly
Knowing which way to trace something so that gravity doesnt have a bad effect on cut accuracy (from parts settling that get cut again)
Shapes can be setup to autotrace in foamworks which takes the tracing process out of it! (it requires that no lines over lap though)
Videos will be posted showing the whole foam cutting process.
I'm working on a second cutter now and need help on wire order for the motors which will be posted too.
Just ask any questions you have and the video will make sure to cover it.
