Originally Posted by in2steam You are going to have problems with the coolant and the lower section of your 80/20 you might consider a subfloor/subbase now, like a drain catch for a wash basin and then raise up the 80/20 little, you will need slope of around 1 in 48 or 1/4" per foot other wise you will get pools and then swarf build up and then stink(uck).
The 80/20 flexes some in my experierence with machine guarding, so a very good silcon should be used, I have a personal prefernce to GE silcone II clear myself.
chris |
Yes, I planned on putting a drain the the base and the coolant will drain below the entire enclosure into a container of some sort.
The bottom panel slopes towards the front of the enclosure and the enclosure overhangs the workbench, so my plan was to put at least one drain up in the front of the bottom panel. Probably more all along the front edge.
It sounds like maybe I need more of a slope though?
