Thread: Key Remapping
Old 03-26-2007, 01:03 AM
MarcL MarcL is offline
*Registered*
MarcL is on a distinguished road
Tazzer wrote:
Anyone know if it is possible to remap the shortcut keys on a Centroid M-400
Such as instead of Alt+S for cycle start you can remap it to number 8 instead.
Reason asking I have a large 5 axis that I am trying to get up and running and I would to be able to have a secondary controller on the other side of the machine. I would like to simply use a keypad instead of a full sized keyboard.
No, that is not possible.
If you need many of the keyboard shortcuts, you might be able to add a programmable keypad (one that lets you program its keys to generate whatever key sequences you want, instead of just being a number pad).
If all you need is a remote cycle start button (and maybe a remote feed hold and/or cycle cancel as well), that could be done through your PLC. Likely it will require some editing of your PLC programs, but that is something a competent Centroid tech can help you through.
- Marc
