Old 03-23-2007, 02:25 PM
philbur philbur is offline
philbur is on a distinguished road
A mild cough should get it.
Here's a typical result from MePro.
1.0 watts. You could blow the material off with a mild cough.
endmill HSS
diameter (mm) 0.8
flutes 2
cut depth (mm) 0.4
cut width (mm) 0.8
surface speed meters per min 90
rpm 38000
mm per tooth 0.00409
mm per rev 0.00817
mm per minute 317
power required (Kw) 0.001
material removal rate (cc per min) 0.102
Phil
Originally Posted by GammaWill View Post
Regarding torque, I wonder how I can calculate that? Does anyone know how I might determine the torque on a 1/32" 2-flute end mill running at 40K RPM, cutting .00625" into 6061-T6 aluminum at 10 IPM? I suspect it is negligible at that rate.
