Chris, As long as the "pitch" and width of the pulley are same (width can be bigger), you should be able, in theory to use any pulley mfg. just be a little careful of the loads you intend to put on the pulley, the cheapie ones bend and flex if belt tension is too tight.......
__________________ menomana |
