From what I hear, you will need a 5 axis machine. The calculations recquired to design an efficient impeller are quite complicated. You need to find the speed that it rotates, the volume of air moved per blade, along with the fact that the air's characteristics change as it gets more pressurized. You would probably be better off just scrapping some old turbocharger, remove the impellers and see which one works best.
Good luck,
Tei
__________________ -Please check out my webiste-
http://www.teilhardo.com |
