Al,
Thanks again for the help.
So your advice is that if it accept 220V 50-60Hz rating, then it shouldn't matter if you plug right into industrail 3Ph-220V?
Also, I am not quite familiar with the use of REACTOR, can you be little bit more precise if you are refering to FILTER REACTOR at Hammond Transformers?
Thank you |
