Old 03-21-2007, 05:46 AM
Willbird Willbird is offline
Willbird is on a distinguished road
Honestly Al I'm not afraid to buy a NEW VFD for this app. Even that would be far cheaper than the rotary phase converter Grizzly specced for this lathe.
Wiring the VFD might be a bit scary for me :-)...I THINK these machines use the "on" lever to actually turn the motor on
IE the motor does not run all the time with a mechanical forward and reverse clutch but rather the spindle lever turns the motor on in either forward or reverse.
If it follows the format of the small jet lathe we have at work there is a two position switch to set the motor to high or low speed.
There is some potential that I may cnc this lathe after I get it.
Bill
