Originally Posted by jime I use a Centroid and digitize gunstocks. It was about a 6K option on the mill. That includes software to process the files. I can go down below .005, but it takes a long time. I digitize at different resolutions, depending on degree of accuracy needed. 25K sounds like a lot. I think you can go less than 6k if you look around, mix and match independent software & hardware. Jim |
Jim do you do this for yourself as a hobby, business or do you work for a stock manufacturer?
Mike
