I work with a guy that made them all the time on a cnc at work. When they would need them in the shop he would cut the end peices out and they would order the spider(rubber peice). It shouldn't been an issue if you have access to a mill. If you are making them on an manual you may want to be sure they are ballenced when you are done. It may not affect your appliction though.
HTH
AC |
