Rekd you are not reading carefully enough. I did not say the US was emulating on a one-for-one basis the behaviour of some of the extremists. I said that the logic being applied to explain or excuse activities such as waterboarding, sleep deprivation or other treatment that is not dignified or humane is that it is okay because the other guys are worse. You come close to saying that explicitly. If you set your standard of comparison low enough you can always claim the high ground. I simply believe that some of the documented and admitted activities of US, British and, yes, Canadian governments and armed forces personnel are not up to the standard that should prevail in a civilised society. |
