Thanks for the info......so far
I'll check for the start/end difference once I get Signgo on my pc.
I managed to get Joycut to drive the Hp7550a last night...so most of my problems are sorted. I will also get Signgo installed over the w/end and see how that works.
I will pick up a Hp 7570 (draftpro) and a Hp 7585a on Satutrday...so theres lots of testing to be done.
Are you using a standard Signgo driver for the 7570? or did you modify one of the other HPGL drivers to suit this plotter, as I understand that there are no specific HP drivers listed in the program. |
