Hi Again
I was just thinking would it be possible to through software just simple send the same data to two diffrent steppers. Such as simply config X Axis Stepper and Y Axis Stepper through Turbo CNC to take input from which ever I/O pin and simply do it that way. In that way both axis would recive the same info. If that sounds like it would work does anyone have Turbo CNC and will it allow you to configure one I/O pin to two diffrent steppers? Again thank you for any help you can provide.
Thank You
Jason Croyle |
