One thing to consider about Haas service is that all technicians are trained at the factory. I know several other names in our area that has tech that only pretend to be factory trained. Also lokk at how many Haas HFO's are out there compared to the other reps. Also take a look at the Haas service vans. Almost any part you would need is in the van. If not, you'll get it from Haas "CALIFORNIA,USA" in 24 hrs. I also have a Haas SL-30 Big Bore. In 2 1/2 years I have had one service call and it was my fault. I run that machine balls to the wall!! Also, you get a core charge on major componets that are replaced. If a servo motor goes out, you won't pay full price. Try that with Fanuc!
Also consider that Fadal makes three lines of machines. Boxed way, linear way and half box and half linear. So make sure the comparison is accurate. I would say that a boxed way may have some advantages, but I would put my VF-5/50 against any Fadal without hesitation.
Haas is responsible for the entire machine. Hardware, software, options, control etc. Most machine tool companies use Fanuc or Mits. You know the blame game. When you have a problem, the machine tool company says its the control company and vice versa.
It is a tough choice, but I say " Buy New" |
