Old 03-12-2007, 01:46 PM
NC Cams NC Cams is offline
NC Cams is on a distinguished road
Some of the OEM bearings at one time were supplied by Fafnir. However they were supplied to a special Bridgeport FS spec and Fafnir and Bridgeport at at that one time were under the same corporate umbrella.
If Fafnir is still following that spec today, you should be OK. If not, and/or you have a under/oversized situation that needs a selective fit bearing deal, you may have some issues.
True "Bridgport quality" stuff is not readily available anymore - some of the OEM quality qualifiers didn't survive when Bridgeport went bell up when they did.
