Old 03-10-2007, 09:21 PM
massajamesb's Avatar
massajamesb massajamesb is offline
massajamesb is on a distinguished road
I think Millman is implying that he doesn't know how to create his Gcode in BCC.
That is what you will have to do first, is get the actual code created. This is generally what every cnc controller runs on. This is where the CAM side of things come in.
Mach does allow for DXF import, so simple drawings can be loaded in without the G code, but the problem is that you must then add all your pierce delay, torch on/off, etc into the code manually.
At this point it would probably pay to learn Bobcad, versus Autocad. I don't know if your newer version of BCC will allow you to import Autocad drawings into BobCam. You may have to draw it all in BobCad. This is something I would ask BCC.
And by going by the pics of the work and parts Millman has posted up, I highly doubt decorative art is on his mind
Not unless you can justify making a coffee table or something out of 3" thick steel
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
