Originally Posted by diz Hi Chris
We have the same problem as yours (machine wasn't working for a long time),
nhead lube problem (failure n61) , we have parameters from our machine but the problem is we can't change our parameters on second page op1-16. Do you know how to change it and what parameter we have to change to get rid of that failure.
And one more question , does Your machine work under that failure (61) because we can work but when we turn on auto mode it works in single step mode and when we turn single step mode it works in single step
Best regards |
I believe ours did the same as well. When i put in the original parameters in they didnt work. Then after recieving the ones from mitsu, i was able to change it. I later found out from the previous owner he gave us parameters from another machine. Another user had similar problems and i sent him my parameters, and his machine worked. Send me a pm or an email and will send you my working parameters and hopefully you will have some luck.
