It simpel..
Go to "trim" and select "break in many pieces" or what ever its called...
Set the tolerance to 0.001 and click the "lines and arcs" or whutnut..
The problem is caused by endpoints...a spline has max 2 points..a start and a end point or 1 if it is a closed chain-spline. A mill for example can only move in lines and arcs, and a spline have multiple arcs and lines but no breaks i between.
i hope it makes sense
Million |
