The default MPFAN in V9 contained some limited logic for this. To do it properly, open the .pst file and find the following section:
Code:
pxyzcout #Map coordinates
if rot_on_x,
if cuttype = zero, pxyzcout0 #Toolplane Positioning
if cuttype = one, pxyzcout1 #Axis Substitution
if cuttype = two, pxyzcout2 #Polar Conversion
if cuttype = three, pxyzcout3 #Simulatneous 4 axis (Multi-axis)
if rot_ccw_pos = one, csav = -csav
if mr_rt_actv <> two,
pcoutrev
if index, pindxcalc
pfcalc
else, feed = fr_pos
else,
xabs = vequ (x)
feed = fr_pos
#Check flags and change orientation # - eap 1/17/03
if xflip = yes, xabs = xabs * -1 # - eap 1/17/03
if yflip = yes, yabs = yabs * -1 # - eap 1/17/03
if zflip = yes, zabs = zabs * -1 # - eap 1/17/03 The xflip and yflip and zflip variables are the ones you are really interested in. The logic needs to be modified to work properly. Change it to:
Code:
if xflip = yes,
xabs = xabs * -1
i = i * -1
if yflip = yes,
yabs = yabs * -1
j = j * -1
if zflip = yes,
zabs = zabs * -1
k = k * -1
] Now find the variable initializations in the post:
Code:
xflip : no #Reverse X axis orientation - eap 1/17/03
yflip : no #Reverse Y axis orientation - eap 1/17/03
zflip : no #Reverse Z axis orientation - eap 1/17/03
and change them to:
Code:
xflip : yes #Reverse X axis orientation - eap 1/17/03
yflip : yes #Reverse Y axis orientation - eap 1/17/03
