When you offset an inside cut, the geometry gets crazey. You may end up with overlapping lines that you do not "see". Try offsetting line segments one at a time in the inside cut areas and you can see the problem develop. I just offset up to a trouble area like that and then join the offsets that are good enough for final geometry. Remember you are looking thru a microscope and the finished part will look different. Doing letters is difficult as they can be complex and perhaps a re-size would be easier...I reset the line width on the offsets to see a realistic preview of what the tool would do. |
