Originally Posted by philbur Hole diameter precision is mostly about procedure and tool runout and not really about CNC performance. You will not get 0.0001" with a boring head. Reaming may get it if you're good. |
i said boring head as an example of the type of upgrade where i could put more money if i would go with a SX3 instead of a tormach but you are right that reamer would be better at this job or actualy honing in a way to finish in thight tolerance
Originally Posted by philbur The positional tolerance on the holes will dictate CNC precision and repeatability requirement and the size of the hole will dictate the machine stiffness/size requirement. |
that would actualy be what i would want people point view on, i do understand that these machine tend to vary more from one another but in a overall point of view do you think i might be able to get pretty close to what i am looking for, i definitly should have precised more the size of the hole, i am talking of hole where the size would be between 1/8 and 5/8 and range from 1/4 to 3/4 inch deep, but i do understand that those machine are as tight as big machine, i am mostly looking if those machine have so far respected there advertised accuracy or if they have so far tend to be uterly off precision wise to what there advertised.
Originally Posted by philbur Just some thoughts from a novice.
Regards
Phil |
thanx thats what i am asking and it helps me into my soon to be decision
