Hey,
that looks good!I think I might buy a couple of the,4.5 VDC, 187 oz/in Torque, 400 Steps per Revolution, 0.9° Step Bi-Polar Stepping Motors. Good link..
I believe the stepper I have that I got out of lazer printers are .9 degrees and 400 steps prer revolution. but they are only 85 or 100 oz in.They are the same motors Balsaman has. The only info I could find on the net about them was this.
7)
Japan Servo 85 oz-in 400 Steps/Rev . $29/ea,
(- and if you want to see what a quality motor looks like inside, here is the dis-assembled motor, showing the clean design and double stack with ball-bearing construction.)
Japan Servo TYPE KP56QM2-001, with Ball Bearings on each end of shaft. (note, unless you burn out the windings, and this takes at least a little effort, the only failure mode in step motors is bearing failure - which is easy to remedy as well as rare with Japan ball bearings)
NEMA23 mounting flange: Motor Length = 75mm from flange to rear of case, Motor Diameter = 57mm. Shaft Length = 14mm, Shaft Diameter = 5.9mm
6 Wire CT windings 3.5 ohm - 0 - 3.5 ohm,
Maximum Current: Center tapped - 1.5A , Bipolar, full winding - 1.0A
note: These motors have been carefully removed from surplus assemblies - leads are 75 mm long, and may require extending for some applications. We guarantee your satisfaction with these motors !! Limited quantity available. $29/ea
