Oracle its a little hard to navigate his website but all of it is there for free. The plans and software. It really looks like if you have a router table you could in sence could build this pretty cheap with only having to buy the electronics and material. Also I think you could convert your 3 axis router as well. Just take mach3 and goto the last line of the gcode-hit run from here-reverse-start. The onlything that I would worry about is some of the cams that are outer there have a hard time doing undercuts and hollow areas. So you might have to build your model in layers rather that just one peice. |
