Originally Posted by gus spray bottle of simple green and have at it |
Really, you use simple green? Then rinse it off with water?
I've been going around it with stoddard solvent. Just mucked out the sump, there was about 1/2 gallon of machining detritus/slurry in there with poor access - disgusting. Do you use the cast in sump, or drain the coolant to something a bit more accessible?
