Thread: tool indexer
Old 03-24-2004, 04:57 PM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Oh, 20" swing is too big of a machine for this little turret indexer.
I'm not sure how large diameter the Dorian Turret is, but the 16" turret (horizontal axis) on my Eagle lathe (which is also about 20" swing) is about as small as I would ever want, when using a 12" chuck. This gets the bars up or down or back far enough to clear the chuck. Most of the time, I can use boring tools within 60 degrees of each other and still be safe. I still check it carefully with the rapid override turned way down, though
