"Why the predisposition to carbide?"
It was my hope that the factory ground edge on carbide would wear longer than HSS. I know that HSS could be resharpened, but for some time, I am going to lack the the equipment and skill to do sharpen an endmill, so I need the bit at least to be true and sharp--even if I cannot be.
"what are you machining?" Largely, mild steel, aluminum, and hard plastic.
I have several projects planned. I am going to be making some motorcycle/bicycle type drop-out parts. I don't know whether or not I'll go with steel or aluminum. I am going to make some front vehicle suspension type parts, They will be steel.
I have some other little projects I want to make, some optic holders: mirror and beam splitter holders, who knows maybe even a spatial filter. I may be tempted to lighten my bike a bit, which may have anodize on parts. Lastly, I may help a friend make a boat-accessory from stainless, but I know whatever good bit I use for for, won't be good for long. I need to look into some kind of coolant situation.
I had planned to get just a few sizes or endmills say, 1/8", 1/4", and 1/2" in carbide, but perhaps I should get a set of TiN HSS too, if not for in-between sizes, but for practice. The TiN might be slicker than the carbide for aluminum.
