Do the walls have any draft angle? otherwise you can just use a long series ball nose. I think deflection could be a problem with a full 6" deep pocket, plus you will need to go to a large diameter end mill to get the length you need. The cutter will cost you an arm and a nut.
Are you using the mill to make it difficult on yourself?
Maby a boreing head?
work smarter not harder
__________________ Live free or die |
