Trouble with DXF to G Code Transfer | | I'm having trouble using the DXF files I downloaded into TurboCad in the SheetCam program. The DXF files are model airplane plans that I've download from the net. When I select the fuselage bulkheads from the plans, I'm able to load them into SheetCam, convert to Gcode, and run the Gcode on Mach3.
When I select wing ribs, Sheetcam is unable to create toolpaths for the design. I'm not sure why I can't get it to work. Does anyone have a solution to my problem, or suggestions for alternate software if that will work?
Thanks for any and all help. I've just finished my HobbyCNC machine and I'm anxious to cut out some airplane parts.
Mike |
