Yep, there is no automatic way but, there is a graphic tool path editor inside Surfcam that works pretty good. To use it you select the tool path you would like to mod and pick the icon "edit nc", it looks like a pencil with an eraser. You can use the down arrow key or you can use the mouse to pick an area to edit. I strongly recommend that you verify the tool path always when using this process. The graphic editor allows you to insert moves, delete moves, edit moves (accept arcs). Display the tool path and then draw a point where you want the path to move to. To put an exit move into the tool path go to the edit nc process, then mouse pick the rapid out move, and use back up (use the up arrow) until it goes to the end of the move then insert a line move, and pick that new point you made earlier, you must also edit the rapid position accordingly. Hope this helps |
